TheFlyingBrit
Okay this is an interesting one. Having taken the dubious AR7000 out of the Mustang and replaced it with a new FRsky X8R. I was deliberating what I should do with the AR7000
, then the thought crossed my mind. Why not put it in the Vampire, get it all set up tonight on my transmitter then when I get another decent receiver I just swap the receiver setting on my Transmitter.
As with the Mustang all the wires where tied again, just like a bunch of Christmas tree lights left over from the previous year (a right tangle of wires). I eventually fathomed out everything including the steerable nose wheel (stumped me for a bit) I forgot about that.
This is where the problem occurred, I don't have a 4s battery suitable to power this plane at the moment. So I brought a 3s 2200mAh 30c Lipo, the plan being just to use it for setting up and testing.
It worked fine, I got the Ailerons, elevator, steerable nose wheel and retracts all working and in the correct direction's. However, when it came to running the EDF motor "NOTHING". The ESC went through its sequence but as soon as I armed the motor I got no engagement of the motor.
I decided to re-calibrate the ESC, starting the sequence with the throttle on full and connecting the battery to the ESC/receiver. The beep sequence started as normal, but I noticed there where 4 beeps, just before the long beep and throttle stick reset.
The 4 beeps normally signifies a 4s battery, if the ESC see's a 3s battery then there are 3 beeps etc etc.
Needless to say there was no change, the motor stayed stationary so back to square one.
I can't seem to get my head around the issue tonight, probably just over tired. I can only assume the ESC stopping the motor from starting because its expecting a 4S ? maybe its some kind of voltage limiting function. I am aware you can program ESC's with specific functions like brakes, or specific battery size 3s,4s etc but thought by doing a re-calibration that would reset it to a default setting ?
The ESC is also buried and secured below the battery tray with cable ties so I cant get to it easily. The only 4s batteries I have are 5000mAh with XT90 connections so cant even try them out
either.
Does anyone have any suggestions as to what is happening or had a similar experience ?
