The-One-Who-Never-Crashes
TOWN-C Aviation
Lifting power is around 3500g.
A Y6 with the rail system is an OK choice, but keep in mind that the more "arms" you have on your multirotor, the more stable it will be. A regular Hex (with six arms) is more stable than a Y6 (with three arms), even though they have the same number of motors. It depends on the type of payload that you want to carry. If it's hard-mounted (screwed, taped, nailed, etc.), you can use a Y6. If it's attached in a way that allows it to swing back and forth, a Hex is highly recommended. Also, if you want more stability, consider using longer booms.
