After 78 years, the helicopter has been reinvented. SureFly is a personal full-scale helicopter/VTOL aircraft designed for safe and easy flight.
An experimental is not a Type Certificated aircraft
https://www.faa.gov/aircraft/air_cert/airworthiness_certification/sp_awcert/experiment/
And the helicopter has not been re-invented. It has taken a huge step backwards. When you add up all the blade tip losses of a multi, losses in multiple drives, and losses in rotor disc solidity, they are not even close to the power efficiency of a regular helicopter. There's a big love affair with multi's because of market hype. But re-writing the laws of aerodynamics and power systems engineering is not going to happen.
Multi-rotors have several problems with aerodynamics:
1) they have to maintain significant throttle "overhead" for stability control. Helicopters do not - they can be operated at maximum collective pitch range and still maintain full roll and pitch control with the cyclic - important for operating at the edge of the aircraft's performance envelope at maximum payload in turbulence, etc..
2) multi-rotors are most efficient in hover, least efficient in forward flight. Helicopters are the other way around and enter translational lift like an airplane with forward airspeed. Even the handling of a helicopter is the same as an airplane in forward flight, short of collective management. Multi's depend totally on frame tilt angle and differential thrust to maneuver.
It has to do with the fact that kinetic energy is given by 1/2mv^2. It takes four times more energy to move a mass of air at twice the speed, compared to only twice the amount of energy to move twice the mass of air. In both cases, the same amount of momentum is conferred (m*v). And you must displace air equal in mass to the mass of the aircraft to become airborne. So the helicopter moving a mass of air at slow speed with a single large rotor is simply more efficient than moving the same mass at high speed with multiple rotors with higher disc loading.
3) To get Type Certification, demonstration of maneuverability, control, and landing, without power, must be done. Even the largest multi-engine airliners must demonstrate it. It is why airliners are equipped with emergency ram-air turbines (RAT) for hydraulic and electrical power for the flight systems. This is impossible to do with multi-rotor fixed pitch designs. Parachute emergency landing does not meet Type Cert requirements.
So while the market hype will continue and breed a lot of crazy schemes, the basic laws of manned flight and aerodynamics are set in stone. You can get a Russian-built Micron coaxial, or a US-built Mosquito helicopter, and enjoy manned flight safely, and with quite high performance for an ultralight aircraft. I looked over the Micron at Heli Russia 2016 when it debuted and I am quite impressed with it. It is a much more robust design than the Mosquito, IMO, which I have flown quite a few hours.
