Hey guys, I would normally troubleshoot this myself, but I am a little tight on time. I just flashed CF back onto my naze after running dRonin for a little bit. I had to short the boot pins to get it flashed, but it connects to CF configurator now. First I went back to CF 1.09 because I had some good settings on that version.
Problem is that I can not get the motors to spin up and the ESCs will not calibrate. I moved to the latest version of CF and same problem. Here are the details:
-RG12a ESCs flashed with Blheli 14.3 I believe.
-First time flying with CF on my Taranis. The same setup flew fine with dRonin on the Taranis.
-I've tried ESC calibration through motor tab and CLI. Not getting beeps at end to confirm calibration.
-Naze makes proper beep sound when trying to arm via TX, but the motors do not spin.
-ESCs use Oneshot and I've tried calibrating with oneshot option selected and not selected.
Since last flying CF all that has changed is my TX is now the Taranis and my ESCs have updated versions of blheli.
Thanks guys, I'll keep trying and will let you know if anything changes.
