Bikerboy,
Yes I did, but when I started adding my esc's, receiver, battery, and everything else, I didn't like the way everything was mounted. There was no planning for them, so I did a redesign. I started by adding the lower battery tray/esc holder, but then needed to turn the craft upside down because of the PDB, then got fed up and started over.
Dan,
My motor angle is set to 30 degrees and I will be using the 8x5 HQ props. The motors are mounted as you see them, and the height of the motors is about 1.5 inches. I have no idea what you did up there. I'll just measure 4 inches from the prop shafts to find where the tips will be and then rebuild a new tail assembly. What do you think of a 1/2 inch gap between the props?
Tomorrow I will rebuild the tail boom, finish soldering the ESC's, then plug into Baseflight for the first time.
