FlyerInStyle
I built a tiny trainer. everything went well, BUT that was until...
I discovered that my plane was not turning because my tail was on crooked. the tail half of my plain was all crooked. but I only had a tiny piece of foam left. so the only type of fuselage that could fit on the piece of foam that I had at the moment was the ft mini scout fuselage. except...
I just took an old ft mini scout completely crashed and unflyable. What I did is I just traced the crashed fuselage out.
what I did then is I used Experimental airlines body tubes techniques:
to put it together.
After that I slid the other crooked fuselage of the tiny trainer in a little bit diagonally, and it becomes even. but then, the nose tapers down in the front, and I like how it is. it also becomes pretty tail-heavy, if I do not place the motor close to upfront . where and how can I place it for maximum efficiency?
please help!!
please help!!
