Hi,
I am planing to build up the xhover stingy frame and I have a few uncertainties.
1. I want to use the Betaflight f4 fc but I don't know where to solder my spectrum receiver that takes 5v.
spektrum receiver: https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPM4649T
Betaflight f4: https://www.getfpv.com/betaflight-f4-flight-controller.html
2. I also want to use the wrath 32 v2 escs but I am wondering how I would solder the motor wires because they don't have full pads.
Wraith 32 V2 Blheli32 35A esc: https://www.getfpv.com/airbot-wraith32-v2-blheli32-35a-esc.html
3. In my previous builds I've always used the tbs unify HV and just hooked it up to vbat and then powered the camera with the vtx. However this time I would like to use the tbs unify pro V3, would I wire it just like shown in the diagram above and instead of supplying vbat, just connect the positive lead to a 5v power output. The betaflight f4 is limited to 1500mA in total will this be enough to support the camera, receiver and the now the unify (on 800mW)?
TBs Unify Pro V3: https://www.getfpv.com/tbs-unify-pro-5g8-v3-sma.html
Thank you for all your help.
