RedTwenty
Hello
I have a love/hate relationship going on with my Talon Tricopter.
I've got it flying, tuned in etc. etc. and it seems to not have a problem until...
After a bit of hovering I move off slowly for some out and back type circuits (in the fairly tight area I have been testing in behind the house). All seems well and then suddenly it is as if motor 2 dies momentarily. Of course it tries to stabilize itself (I have tried this with self-leveling and and off) but it over-corrects wildly and drops to the deck before I can regain control.
I have tried replacing the KK2.1 control board and also replacing the motor and ESC on arm 2 with no change.
The daft thing is it never used to do this. On the first KK2.1 I had it flew fine but I broke it after a crash and had to replace the board and the tail portion. Could I be unlucky enough to have 2 dud KK2's?
That said, I do have the problem with the 2 newer KK2.1's that only M1 has the 5v pin connected so I have had to solder a jumper underneath the board between M1 and M4 to get power to the tail servo - could this be causing a drain on the M1 output when I start maneuvers that is knocking out the KK2 somehow?
I am running a very soft tune with Roll/Pitch at P=30 I=20 and Yaw at P=40 I=30
A few specs to complete the picture:
Controller = KK2.1 upgraded to Steveis latest beginner version (but have also tried V1.6)
Motors = NTM Propdrive 28-26 1000kv
Props = SF 9 x 4.7
ESC = Turnigy Plush 25A with basic changes made (Nixx, low voltage cutoff, mid timing)
Going a bit insane here trying to figure it out so would appreciate any thoughts from the community...
Cheers,
Mike
Red20RC
Props = SF 9 x 4.7
Cheers,
Mike
Red20RC
