Demonspeed69
This is my first Naze32 so it is all new to me. This is a brand new, unsoldered board and I am using a Mac book pro.
So far I have downloaded the “Silicon Labs VCP Driver install disk”, applied the “uninstaller.sh” to the terminal command window and installed the VCP driver.
Restarted Mac
I downloaded Baseflight
First try:
In Baseflight I go to the firmware flasher, Click on “full chip erase”. With “Stable 2015.08.26 - 20:40" checked in the available online firmware window, I click the “Load firmware [online]” button. The firmware info appears in the Github Firmware Info window.
I plug in the Naze32 via a micro usb to usb cable. The lights on the board are as follows;
Blue LED steady on
Red LED Flash
Green and Red LED flash
Green LED Steady then flash
Blue LED only.
I then click the “Flash Firmware" button in Baseflight.
Baseflight says “contacting boot loader” then “No response from the boot loader, programming: FAILED”
Second Try:
Close and reopen Baseflight.
Go to Firmware Flasher.
Click the “No reboot sequence” and "Flash on connect” and “Full Chip Erase” boxes
With “Stable 2015.08.26 - 20:40” in the available online firmware window, I click the “Load firmware [online]” button.
I then bridge the “Boot” pads on the Naze32 board with a pair of tweezers and plug in the usb.
I then only get the blue LED and nothing happens.
I then click the “Flash Firmware” button and get the same FAILED massage.
It seems as though the laptop is not even seeing the Naze.
I tested the usb in the Laptop and it communicates just fine with everything else I plug in.
I have used 3 different usb cables to rule out a faulty cable.
The Naze32 seems to be working due to the green light flashing when the board is tilted indicating the gyro is registering moment.
Could it be a bad USB connection on the board?
All the online information and forums I have found indicate that the previous steps should work.
What am I missing?
I also have this information emailed to GetFPV support, where I bought the board.
Thank you for any suggestions.
Restarted Mac
First try:
Blue LED steady on
Red LED Flash
Blue LED only.
Second Try:
What am I missing?
