Turkey_Flyer
Hi, im from Mexico City im new to this forum, I´ve been reading FT articles and treads on this forum for a long time, finally I decided to start this hobby, I have to thank FT guys for making the hobby affordable and easy.
I pick up the plans for the scout in FT page and cut them in my local lasercut shop.
This is my first FT Build, very easy build and looks great.
Everything works great, motor, servos, transmitter and reciver, the only problem is that i just couldn´t get it off the ground, so I look for all the things that are wrong with my plane.
first specs: My specs/Ft specs
Weight (w/o battery): 189g / 115g
Motor: 18-11 2000kv Micro Brushless Outrunner/ 2480 kv 250 size motor
Prop: GWS6030 / 5 x 3 prop minimum
ESC: Turnigy plush 10 amp / 6 amp minimum
Battery: 850mAH 2s Lazertoyz (42g) / 300 - 800 mAH 2s minimum
Servos: 2 x hxt500 (2) 5 gram servos/
Receiver: Turnigy 9X 2.4GHz 8Ch (18g)/
Links of my parts:
Motor: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=5358
Prop: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=27409
Esc: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=4204
Batt: http://www.lazertoyz.com/850-mah-25C-Slim-Line-74V-Lipo-_p_550.html
Servos: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=663
Receiver:http://www.hobbyking.com/hobbyking/store/__12339__Turnigy_9X_2_4GHz_8Ch_Receiver_V2_.html
My plane was clearly overweigth (189g without batt) and when i balance the plane was very tail heavy, i had to use 30g of lead and the battery (42g) at front of the plane to balance it. With the plane balanced the total weight was 259g.
The other problem is that it was underpowered, I look in the forum and this motor was recomended for this plane, but they clearly say the plane must be lightweight.
the only problem I cant fix is Mexico City altitude 2240meters (7349 ft) over sea level, I know air is thinner at bigger altitudes I dont know if this afects my plane.
How I plan to fix it:
-Buy a bigger motor im thinking the Emax 2480Kv ( http://www.banggood.com/EMAX-MT1804-2480KV-Brushless-Motor-For-Multirotor-p-933933.html)
-Maybe change prop but i think that depends on the motor
-Make it lighter, carefully make some holes on the tail and replace the foam with someting lighter, remove exess glue, change reciever I´ve read in the forums that HK6ch receiver works for turnigy9x (http://www.hobbyking.com/hobbyking/store/__12901__Hobby_King_2_4Ghz_Receiver_6Ch_V2.html).
I want to know if this changes could work?
Do i have to change the prop?
how does the altitude of my city affects?
What else do you recomend?
In a future,I would like to build a Mini Crusier or a Mini Guinea, I want to know if my current motor work?
That´s all for now, thanks for your time.
Andres.
Links of my parts:
Andres.
