daddoesntknowall
Newbie foamboard builder
The good news.
We built a foam board plane (thank you Flite Test)
RC kit we have.
A DX9 Tx (we wanted future options)
Spektrum AR610 receiver with remote recevier (belt and braces)
Suppo 50A ESC (I figured >A means harder to kill) with BEC
a Suppo brushless motor 2814/8. 1000Kv I believe.
3Cell 11.2v Lipo, a couple of those
iMAXB6AC charger.
A bunch of 9g servos.
10x7 prop
All WAS good. Bench tested some weeks ago the tx/rx/battery/servos/esc/motor. It literally all just worked out of the box. Watched youtube vids for several hours,. bought the stuff, plugged it in. And everything worked.
Build plane, install stuff in plane.
Servos all work. No motor. Hmm..
Much googling and youtube later, discover how to reset throttle range on ESC and put it in auto LIPO detect etc.
Sadly, we're now at this point.
Every time I "reset" the ESC, that is, switch on tx, throttle up, connect battery wait for beeps, throttle down wait for ready beeps, I can then throttle up and as it gets to 25% the motor spins. It spins and sounds normal, nothing nasty, no heat, no weird noise, for maybe a second or so then shuts down.
Now it doesn't run.
Turn all off and on. Still doesn't run.
Go through the ESC reset described above and it briefly works again.
So, i'm thinking now that maybe motor is pulling too much current perhaps (based on stuff I've read) but don't know how to properly measure that and in any event the 50A ESC would seem to be more than capable of delivering whatever that motor needs. (I have the prop off while trying to get motor to run of course)
Or maybe the battery not up to the job (I have two, voltage is good, all balanced, both fully charged)
Whether the motor works or not all servos continue.
I thought maybe some throttle cutout on the DX9 so reset the model config, ensured nothing fancy is enabled.
I'm all out of ideas and am at the point where I'm just about to buy a matched battery/ESC/Motor combo from flittest or another so I have something else to test against.
All suggestions for next steps most welcome!
Many thanks
RC kit we have.
iMAXB6AC charger.
10x7 prop
Now it doesn't run.
Many thanks
