On your pylon spars you can go with a second aluminum spar if you choose, I did. But! Dont make one till you install the fuse bottom plate or youll throw the fuse side walls off. That fwd spar might give you that issue sence you installed it allready.
Not im not clear on what you ask about the lower fuse plate but from your picks you still need to remove the edging
The red outlined section should match the fwd fuse plate, the foam strip. That little paper is there just to close up the side wall edges for a clean look.
The green arrow is the little tab the fits under your hstab,that will fold up and glue in place like a AB fold and apart of the side wall.
The blue outline section, do not glue this inplace when you install the bottom fuse plate. The fwd line acts as a hinge so you can install you hstab later in the build then glue that section inplace.
Not sure if i helped with your question,if not post a pic and highlight your question and i can help you out some more
