I'm gonna try to make it balance with just battery weight. I'll soon know if that is possible..
Added 1 more layer of bracing to the motor mount. This piece will also act as the battery shelf.
Wrapped the next layer of the nose.
For the last bit of the nose I need to make it look as rounded as possible. I'm using some thin strips of foam with some bevels on the inside.
The pieces get bent and taped together to make a slight curve.
The tape holds the shape so I can lay down some hot glue.
Once the curved piece dried I attached it to the fuse using the same tape method.
Was a little tricky to attach, but it came out really good I think.
Prop clearance came out PERFECT.
Next up is the last bit of fuse skin on the tail.
