Whats the AUW looking like right now? We should be able to do some back-of-the-napkin ballparking based on approximate wing area and get some idea of wing loading and stall speed...
On edit: Looks like this has the same span as the top flight gold edition giant scale. I know the wing design is slightly different but we can use that as a good reference for wing area. That model has 1376 sq.in. of wing area and is advertised between 360-400oz AUW. That's between about 37.7-42oz/sq.ft. standard wing loading and 12.2 - 13.5 cube loading... very reasonable for a warbird.
It wouldn't surprise me if your model came in at 160-190oz... maybe even less. That puts the standard wing loading between 16.7-19.9oz/sq.ft and cube loading between 5.5 and 6.5. Cube loading that low is the realm of trainers and parkflyers and half the cube loading of my P-40. I think this will slow WAY down and land light for you. You can't do flaps since you'd be landing on them, but I don't think you were planning them. I'd just put some protective material over the gull section and put her down gently
Might think about putting a good hand-hold location with a bit of sand paper glued to it for more throwing grip to hand launch, and you'll probably want a buddy to launch it, but should be good
