Looks so good man, I love it.
Did you just wing the paint design?
Jayz,
Thanks for the pics! How's your back doing?
No prob man. Now on the back its better to a point i cant pick up much. But im having a bad week i guess cause right now im in the hospital on antibiotics do to a bad infection in my nose form a cut i had. Im falling apart lol
Man, you just can't get a break. When it rains, it pours doesn't it? Get well soon brother.
Ok (jaxx) here you go man some side shots with the spinner and some of the pod and hatch mod for you (nic) showing how much space you have to play with thats 2 1800 4s under the canopy section showing how much room you have and all the fwd play area for cg balance and the short pod. Still very easy to swap(easier) and you dont have to worry about taking it out to change batterys the hatch makes it ten times easier and faster for battery change
That's a sweet looking plane, jayz! That hatch and short pod are great designs.
Get better so you can get out and fly. (or so you can get back to work and buy more stuff to build more planes)
Hello Guys
Here is my realization of the nnMig3 - this is my first built of this plane and i didn't have at this time the proper aluminium spar (not available at the Home depot) so this is a 3/4 inside instead of a 1/2.
The result is a wing just 1/4 thicker, i had to dig the foam for the spar to fit in as nic did but the servos are just glued on the foam (no digging there)
I had to change a bit the fuselage so the thicker wing would fit in.
I used the hatch idea as the battery needs to be just in front of the cockpit to balance the plane properly.
That is all i did.
I just minwaxed the plane today and i will go for maiden this week after a quick airbrush set if i have time.
My power system:
NTM 3536 1400kv
HK 60A ESC
NanoTech 4s 2200A
I used 3 regular HXT900 9gr servos from HK
FUTABA 14SG - GPS module in the plane so i can get the realtime speed.
Propeller 8X4E but i'll try the 9X6 and 10x10 as soon as i can lay my hands on some.
If the experts have any comments before i go fly ;-)
I'll build another one with the regular 1/2 spar asap since i was able to train on that one.
I want to sincerely thank Nic for his contributionS, and i want to thank those who participate on this forum.
Nic, i 'll make a donation and i encourage all those who can, to do so.
You will find the donation link on the first page if i recall correctly
Regards.
Guy
View attachment 33436 View attachment 33420
I went ahead and trimmed the nose a bit and boxed it in. I kinda like the smooth wing bottom. my ft Mustang always belly landed badly from the scoop dragging. it looks better with it, but if it won't hurt flying. I'll property leave it smooth
I need to get the big foot 10 ordered up. even though I might test fly it once with this motor I had around
