I am helping my 13 year old son build a FliteTest tutor. The build went fine, but we are having trouble getting the electronics to work properly.
We have a Spektrum AR620 receiver and a DXS transmitter.
The tail flaps and rudder are working fine, but the motor will not turn.
We have checked to make sure the motor on/off switch is not activated, and have tested the receiver functionality by plugging the wire that goes to the rear rudder, into slot #1. Nothing happens. What does that mean? does that mean that the receiver is not working properly?
Please see attached image. This is how I understand it needs to be setup. Battery plugged into ESC. motor plugged into ESC, ESC plugged into slot #1 one, Tail flaps and rudder plugged into 2 and 3. (in this configuration as shown in the picture, the tail flaps and rudders work. the motor does not)
Does anything need to be plugged into the very far left slot labelled 'battery'?
Also do you know what the small red plug is hanging off of the ESC? does that need to plug into the slot labeled 'Battery'?
Any advice on how to get the throttle working would be awesome.
many thanks
-Dan
many thanks
-Dan
