So In my general cheapness I was looking for a substitute for colorfab LW PLA. In my travels I found this. It is polylite LW PLA. Apparently it is already "foamed" and you can print using standard PLA settings. It is 31.99 a roll.
https://www.amazon.com/dp/B09H2SC1CX/?tag=lstir-20
According to the description:
However, don't make the mistake I made the first time and get the standard polylite PLA. Make sure what you get specifies it is lightweight. The standard polylite PLA is rebranded PLA+. This is what I accidentally bought the first time. I am sure it is fine for PLA, but if you want the lightweight stuff... DO NOT BUY THIS!
https://www.amazon.com/dp/B01IAVQP2C/?tag=lstir-20
It is 22.00 and standard PLA. I am sure I will eventually use gray PLA. Again, this is what NOT TO BUY if you want the lightweight, use the first link.
So after I bought it, I started looking for how to print with the stuff. This guy has a pretty good write up on it. It seems like a happy medium between LW-PLA and standard in both strength and weight, as in it is stronger than LW PLA it seems and lighter than standard, but not quite as light as the color fab. However, it is allegedly very easy to print. I am planning on using this for the shark I am going to build. I will keep you posted, but this stuff could be a game changer. I will get to printing the shark after I am done with the color fab LW-PLA Model D I am building.
- 🚁 【Light Weight PLA】 - PolyLite Light Weight PLA is a low-density PLA (0.8 g/cm3 compared to 1.17 g/cm3 for regular PLA). It prints using the same settings as regular PLA (temperature and flow rate), making it easy to print and compatible with most 3D printers. It will not foam when printing, which saves you from a lot of troubles brought by active foaming of traditional light-weight PLA
- 🛠️ 【High Rigidity & Good Layer Adhesion】 - Our Polymaker lightweight PLA has high rigidity and good layer adhesion so you can easily get some stiff parts of the radio-controlled plane with it. PolyLite PLA is a worry-free 3D Printer Filament Grey Low Weight PLA that has great bed adhesion, very consistent color and dimension accuracy, and no warping, no jamming, no blobs, or layer delamination issues. 【Note - turn off the fan for the first layer for improved bed adhesion】
