I recently assembled the power pod for a Tiny Trainer. Some of the instructions weren't clear and I had tried to attach it using four screws instead of the two it showed in the video which didn't work. I also used the medium sized screws rather than the smallest ones that came with the motor. After a while I tried just using two but it still stuttered until I loosened the screws slightly but, it still stutters intermittently.
The battery is fully charged, according to the tester it is around 11 volts.
I can't see any specific damage to the motor but it's obviously stuttering:
https://youtu.be/8LPZS3tmmO8
I've calibrated the ESC several times but I still get the same result.
Most likely I'm thinking the screw went up into the motor but given the behavior, it seems like the ESC could be an issue. Anyone have any ideas where to start? The connections to the motor all look good. The ESC's connection to the AR400 receiver did take a rather rough push to get into the receiver. I don't see any visible damage or impact against the copper coils.
I have since taken this off the power pod and tried powering it up but I'm getting the same intermittent stutter. I've also tried reversing the leads but it does the same thing in clockwise motion.
