I'm building a new quad based on the White sheep frame. It's the first time I'm messing with LEDS and not everything goes according to plan
LEDs are more/less working : they light up, but the colors are all messed up. IMHO, it's definitely a serial sync issue but I don't understand why.
My setup :
4 WS2812 LEDS strips, 8 LED each, 1 strip per arm, nothing fancy so far.
LED strips are powered using a separate BEC rated for 1.5A (4 strip x 8 LEDs * 18mA = 576mA, should be OK) and are chained : Naze32 pin5 -> strip 1 DI, strip 1 DO -> strip 2 DI, and so on. I also "chained" the +5V and GND. The DI-DO chaining has be triple checked.
Flight controller is a Naze32 Afro rev6a 10DOF flashed with Cleanflight 1.12.0.
Using PPM (obviously), LED feature turned ON and I tried various LEDs configurations. Sometime colors are almost correct, sometime it's only a huge mess.
Any idea of what is going on here ?
My setup :
