pressalltheknobs
If you have an i6 there is no such thing a "2 aileron". That's some "Spektrum" malarkey. For 2 ailerons you just add a mix to one of the AUX channels.
So it's important to say what Transmitter you are using. I'm assuming a FlySky/Turnigy i6 since you resurrected this thread.
Could be you have one of the mixes enabled and the Throttle channel is driving the AUX channel... The i6 channel order is AETR
Whatever TX you are using, it should have a channel monitor which will tell you what the Transmitter is sending. You can look at that and see if the Thr channel and the Aux channel move together. If they don't the problem is most likely on your model and you probably have some wiring confused.
