I agree with Vincetel F-14 (above) since I not only made that swing wing aft, i used the same plan to have a design that doesn't exist. That design is super tough and flies not only can be moved aft, it morphs to fly swept forward controlled by the throttle. His simple 1 servo design has a large weight bearing area that allows easy movement of the wing.
If you look below and follow his exact positioning of servo, arms etc, it will not bind up on you. I added graphite powder on my surfaces to mine so I can get the wing to move forward as well as aft.
Maybiz on RCgroups allows downloading so you can have a F-14 with a movable swing wing by throttle. It is simple and fool proof. On one arm I added a threaded setup so when the other wing touches, you can adjust the other wing so it does the same. Look for MDC F-14 plans and pic in the pusher prop section.. Vincetel does a nice job of decorating his, mine not so. Still have it after many years.
