Maiden Flight
Perfect weather to test fly the Pun Jet today. I stated with a couple of glides into tall grass. This resulted in little learned about the airplane and the beginnings of a crumpled nose. Deciding little would be learned by gliding and I was only damaging the airplane I began powered testing. I started with a gentle toss into about a 6 knot wind. I pre dialed in a touch of right aileron and a touch of up elevator. I was using a 5x4 propeller and 3 cells. Takeoff power was about 1/2 throttle. Feeling that things wern't going so well I chopped the throttle as I was headed back into the tall grass. The nose ended up with a little more damage and the propeller being so close to the vertical stabalizers ate a little piece out of the RH stab.
After some minor repair work I tried it again. This time with the controls dumbed down way below the suggested low rate setting and expo kicked up to 50 percent. Got it to fly this time but it was a wild ride. It IS fast and it doesn't want to fly slow at all. Controls are twichy in all respects. All of the controls functioned and the CG was correct to slightly nose heavy. I managed about 4 minutes in the air before it got the best of me. I hardly ever crash but I crashed. Damage was major but somewhat repairable. I put her back together and tried it again but it nailed the ground on launch and that is the end of the story.
Here are my thoughts on this airplane.
I'm a HUGE Flitetest fan and have sucessfully built and flown most of their designs. I have build and flown all sorts of models over 40 years or so. Nearly all have been successful. This was a fail.
I could probably mess around with this design and get it to fly alright. But in the end, it is very fragile and really difficult to handle. The combination of really small and really fast isn't good in my book. You ARE gonna crash it to pieces very quickly.
I'm sure I will get suggestions on how to set the little jet up better, but I honestly think I did a pretty good job of it. Some might like it, but it was a disappointment to me. Guess that is why the call it Flitetest and not Flite for sure?
This hobby is all about having fun and this ain't no fun. I would select something else from Flitetest.
Not trying to bash Flitetest in anyway. Just trying to give you guys an accurate report from the field. If a bunch of you guys get them flying well and really like them, I might feel the challenge to revisit the Pun Jet. If I did it again I would quickly build the fast build kit and wouldn't spend any extra effort at all on it making it pretty. I would add some reinforcement to the nose and would move the motor back a little to provide better clearance to the propeller. Hope this info helps someone.
