Hello world,
So I have decided to step into racing quadcopters.
As usual due to financial constraints and me not being a good enough pilot to justify a good expensive frame I have decided to build one myself.
I had a look at the “proper” frames and tried to replicate it, knowing that I might end up with something heavier and bulkier than Luminier and co.
The main element that I was trying to make sure I keep protected were ESC’s.
I have used 3mm polycarbonate, from which I have cut out a rough shape of the frame.
I have used 10x10mm wood as arms and placed them in the same manner as per David’s tricopter build.
I have decided to use KK2 mini board to run it for the time being, powered by 2200mAh 3S battery.
By now it looks like this.
Now the question is what motors and props I should be using for this setup.
All you can see on the photo weighs exactly 300g.
I’m open to suggestions.
Thanks
Dan
Thanks
Dan
