T-Richard
This is a progress log of my project to recycle and old Rc plane and turn it into a sort of fantasy STOL airplane.
Inspired by the huge amounts of nice bush planes available on the market lately I wanted one of my own. I wanted mine to be different and also thrifty!
I was originally going to build another ft bushwacker or grow a simple cub and add some upgrades but this old thing was given to me
it's a very dated hobbyking 1500mm cessna 182. All the electronics were included but the motor was dead, magnets broken, bell deformed and wooden firewall destroyed (it's friction fit put back together in the photo)
So here is the dream;
An inexpensive and different Stol airplane
use the beefed up landing gear coupled with some larger wheels for that bushplane take off and landing ability, i'll be flying in rough terrain
Flaps! I've never had flaps on a plane before so I'll put these old futaba servos to use and put it on the slider of the taranis for manual smooth flap operation!
Vortex generators, because why not? I plan to have them just at the aileron span
Canard wing! I want this to be a bit unique and the nose need to be rebuilt anyways so I may as well do something interesting here. This is like the WREN or Katmai mods but I may decide to go a little bigger for just a bit more of a unique look. it will have a control surface coupled with elevator... should be interesting!
More power! the stock airplane has a 3530 old motor so i am throwing in a modern 3536 on 4s for just a bit more power
FPV and LRS (ish) ; I have a lot of gear and my goal is to make just a few airplanes this year but make them unique and load them up with whatever tech I have lying around, here's what I've got planned...
Pan and tilt camera, 600mw VTx, replace aileron servos with metal gear servos, Osd possibly with GPs, L9R receiver
Definetly a new paint job and finishing... I am thinking flat black and a bright color to accent it.
I've already begun cleaning it up, I've reglued the wing spar, taken off all broken parts and ordered a replacement motor.
I decided to go with a 3536 1000kv that I plan to run on 4s 2250 lipos.
The motor will likely take a few weeks to come so I'll begin work ont installing all servos on the wing shortly. Stay tuned
A last detail, This project is meant to inspire others to re use old gear and sort of "recycle" your RCs. I am not going for a very scale Restoration, I am building my dream Stol airplane that is unlike others and unique to my tastes and uses a lot of parts I already have. I'll keep my budjet low and document the procedure to give ideas to others. Hope this will serve the community.
