I'm focusing on the Piper right now over the C-47 because I actually have a chance of finishing this in time for the contest deadline, while I have an extra month or so to finish the C-47 before Flite Fest.
The left wing is coming together pretty quick. I permanently fixed the center section and I am about to sheet to top of the leading edge. Then comes attaching the jury strut mounts, the wingtip, and a whole lot of sanding to shape the leading edge and rounded tip and trailing edge. Once that is done it will be time to cut the ailerons on both wings.
I've been thinking about paint a little bit. My initial thaught was to use the "Scale Stits System" which uses four more Poly-Fiber products in addition to the Poly-Tak that i have been using to adhere the fabric to the wood. I would need to buy a fabric sealer, a product that makes the fabric more opaque, a filler, and finally a paint (which requires their special thinner, sold separately). The total cost would be about $90. No thank you.
Instead, I'm taking an idea from the world of full scale experimental aviation. Apparently regular latex house paint works pretty well. It is an acrylic paint that adheres to Dacron's polyester fibers very well and even protects the cloth against harmful UV light. I did an experiment on a scrap of Dacron to see how well the latex would stick to the cloth. Needless to say, I'm pretty impressed.
On the right is one coat, and on the left is two coats. The paint soaks into the weave of the cloth and really bonds well to the fibers. The fabric remains flexible, and the paint doesn't crack or flake off. One coat was enough that there were no visible pin holes through the fabric. The second coat did not bleed through to the other side, and left a nice satin finish. Very impressed with the results, and I'm much happier with the cost. Now I just need to find latex in silver.
