Weed eater/whacker engine conversion to 1/4 scale piper cub.
Have you ever put a weed eater/whacker/brush cutter/ chainsaw engine on a rc aeroplane? did it work?
  • yes a chainsaw
    Votes: 0 0.0%
  • no but it didn't work
    Votes: 0 0.0%
  • Total voters
    14
Big prop short landing gear. The edge of the prop is close to the ground, might get propstrike on landing.
Ummm, in 3point, no way to propstrike the ground unless you groundloop severely, but up on the mains there's only 6" typical clearance. With a taildragger handle, you ought to know that.
Bricks
Not talking about landing and prop strike it was sort of a joke when weedeater plane was mentioned. Some planes on take off the landing gear is short and the prop is long so you clip grass on take off`s....weedeater.
Matthewdupreez
aaah now i understand.
yea hopefully mine won't do that
Graeme M
@Graeme M did you say you have made a weedeater plane?
Ketchup
4s mini mustang
yes it will be a tail dragger.... easier to land..... tricycle would look cool though but much more complicated
No. Tail draggers are known to be much harder to land than tricycle gear planes. So many trainers and GA planes are tricycle gear because of it (or at least it's gotta be part of the reason why). Don't expect the plane to be easier to land because it is a taildragger, you will have to work a lot more to keep that thing going in a straight line while on the ground than you will with a tri gear plane, so set your expectations accordingly and learn to use rudder. I'm not even gonna comment on tricycle gear looking cool...
Matthewdupreez
well if tricycle gear is easier to use then this would be awesome
quorneng
Tricycle landing gear is easier to land if you do properly but the nose wheel is all to easily damaged in anything but a good landing.
You only have to look at the full size accident reports for the number of trainer 'bounce landings' that took out the nose wheel. ;)
Matthewdupreez
Hmmm. But I'm only going to fly this when I'm a decent pilot.
M
MCNC
Guest
Admin
If you have not done this already, I would advise you to operate the chainsaw engine as a chainsaw for about 25 hours before you decide to put a prop on one.
