spencertrejo
Junkie
Based loosely on the simple soarer from flight test. Same wing and tail. Wing was modified for ailerons, removed the dihedral and moved the polyhedral to 4" out. The tail has been mostly untouched, besides a small mod on the rudder (no notch forward on the rudders control surface). Will be doing some testing as soon as the weather clears up. Still needs the aileron servos installed and the power plant installed. The wingspan is 56" and will be running a 7" prop. I will probably be redoing the fuse to handle a little better payload, but right now, this was the simplest design for testing. I will concider making plans available if the interest is there.
Any suggestions will be welcome, as this is a new venture for me. I have built many dtfb planes, and have scratch built a few, but nothing quite this detailed.
V3, more pics and details on this starting on page 4.
