That's not Dollar tree foamboard! But it does reinforce the point I was making about how much stress is on the airframe during launch as he is using a 8mm carbon tube for the fuse. The white foam wing is a surprise as that type of foam is pretty weak, so I'd guess that the packing tape on it was put on under a little bit of tension for stiffness and strength. All in all, a pretty cool build and if you have a wire cutting setup, it should be a quick and cheap way to get into DLG.
No, it's not DTFB, and the cabon tube can't be bought at dollartree, but it can be bought at walmart -- or any store that sells bow hunting gear. a CF arrow shaft would be a suitable substitute and can easily be sourced locally for less than $5/shaft.
As for the foam, no it's not the same, but could we strip, laminate sand and tape the wings using DTFB? I say absolutly.
Not everything we use for the airframes can be purchased at dollar tree (music wire, for instance). My understanding is the common FT design goal is maximizing commonly available inexpensive materials, not one stop cheap shopping(thoug occationally, one leads to the other).
Can it be done easily? Repeatably? dunno. I'd like to say yes, but I'm not clever enough to hit on an idea how, yet. With any luck and inginuity someone here can get there, and as the article shows, there have been folks who have gotten darn close with their commonly available inexpensive materials.
