bracesport
open question - what motor sizes (and props) are we running?
"Original" C pack is An Emax 2215/10I was trying to research the FT motor sizes but did not do so well - Is there a kVa spec for the A, B's and C's etc
I KNOW, I checked in after 4 days and had like 30 posts to go through...Amazing how much happens on this thread. It takes me awhile to catch up.
Everyone is welcome.
I am excited to see all of the creations in the making and to see all these birds fly. I have not started yet. I want to try a second maiden on my corsair and then try to get the Spit started. I have not got around to check out any mods I want to do yet. I do like your skin @Rasterize it looks awesome. I hope we see more pictures soon. I feel like I am just rambling. Just trying to catch up. Have fun everyone.
It's listed as 1100kV, you'll be fine!@kilroy07 - so that’s approx 1200kV? Hopefully my 1000kV will do the trick!
I checked after a few hours and had more than 5 posts to read . Crazy thread .I KNOW, I checked in after 4 days and had like 30 posts to go through...
I love this thread! We've got so many maiden videos and awesome build pics to look forward to! I'm not stressing to badly about making it pretty. I'm just trying to make it fly. My flying skills being what they are, I don't expect a long life for this wonderful warbird. I am soooo looking forward to the day I throw it in the air, though! If I can get a good close pass and land it safely, I'll be happy.open question - what motor sizes (and props) are we running?
Damn that looks amazing !speaking of props - I made a spinner by converting the mount from a broken folding prop - the spinner makes the 8x6 prop look tiny! Still needs a bit of sanding and some RED paint! I hope it will work!
View attachment 139631 View attachment 139633
It creates a nice chord profile. It will be a slippery shape in the air too. As you are adding another 6" to the overall wingspan compared to the original FT design, does that mean its a full airframe scale up?So I am ready to start construction on my master series inspired SPIT based on the model below with rounded fuse and under-camber wing design. One more note ... this will be a 48" wingspan plane.
The parts laid out ready for cutting.
I am going to go for a combination style wing between the regular angular wing on the current FT style spit and a smooth top wing like the master series. I don't care for the non rounded leading edge on the master style design so i am going to try the hybrid shown below. I quickly took a scrap piece of foam to fold and try the concept. I removed a section of paper from the inside of the wing to get the smooth top surface and left the paper on the lower flat side. This will give the smooth top and the nice leading edge.
top view: the end of the wing tip is missing because of the small piece of scrap I had. just wanted proof of concept.
Under camber will still be present.
Should be a nice blend of the 2 styles.
What do you guys and gals think? Any suggestions?
Thanks for the tip on the poster board. I will check it out. This is a full air-frame scale up. This is not Overstreet's design, I designed it myself based on his work. I am sure his will be better, but I thought i would give it a shot.It creates a nice chord profile. It will be a slippery shape in the air too. As you are adding another 6" to the overall wingspan compared to the original FT design, does that mean its a full airframe scale up?
One thing with the wing tips that I did on my Spit and I think @bracesport said he would do to his was add poster board to line the underside for strength and less drag. Because there won't be any folds needing glue out to the end of your wings in the under camber area this little trick might help you out significantly.
How did you get the plans for the Overstreets Spit?
I will be really interested to see the details on the build just like how you started out. The master series really takes it to the next level as far as FB goes. Do you have a PDF on the plans you could link in?Thanks for the tip on the poster board. I will check it out. This is a full air-frame scale up. This is not Overstreet's design, I designed it myself based on his work. I am sure his will be better, but I thought i would give it a shot.
As far as the poster board tip I suggested, it's pretty simple. I don't know how skilled of a pilot you are, I know I am not skilled so this is what worked for me and you can take it to whatever variation you like. Maybe you are one of those "only the wheels touch the ground, nary a scuff on the airframe, planes last a lifetime" kinda pilot, then totally disregard this tip. I just used HD poster board, (cuz I do crash a lot, and have bent many wing tips just getting the plane into the car), and adhered it to the underside of the wing with spray adhesive applied to both the wing and the poster board. the poster board was cut over sized before application and trimmed to fit once in place and dried, as shown:
Have you already done the original Spit and now stepping up the game or are warbirds new territory?
Oh yes I do remember seeing this one, you know how to do it right, just like me.i will attach some prints once i build the plane make sure the plans build a flyable plane. I am still working on a few details. yes i built one earlier this year. this after the second significant crash. View attachment 139687
Post Operation
still flies very well.
