DeltaAerospace
(Jets, schmets!)
Hello to all,
My name is Tyler, and since I was a kid, I've wanted to start my own aerospace company. I started with a Cox .049-powered Super Chipmunk I got for Christmas when I was 5 in 1987...and I've been hooked ever since. I progressed to 2 channel R/C (Guillow models, upcycling the .049 engine), then 4 and more channels. My favorite type of airplane, though, was pylon racers. I had brushless Aveox 2T delta-wind motors on 28+ NiCd cells back in ~1995. This was before most people even knew what a brushless motor was, and Lithium Ion (let alone polymer) wasn't in anyone's vocabulary.
I've been into giant scale models since about 2004. I started with Extras, Edges, and other 3D stuff. Then I moved into warbirds...and modifying them (like full-sized guys at Reno do) to make them more powerful, stronger, and faster.
During all of this, I attended first Technical college (for an AAS in Manufacturing Engineering Technology), then University (for a double B.S. in General Physics and Chemistry).
Then, I see this video come out from Flite Test...Red Bull Air Racing challenge...ok, ok, Reno is a separate racing organization, but this is still a really cool coincidence! For the past 2 years, I have been amassing parts, tools, and raw materials to build what is basically the ultimate R/C airplane.
I am basically creating what is a full-sized airplane which has been scaled down, instead of a wood or foam model which has been scaled up. Here are the specs:
Length: 96in.
Wingspan: 110in.(x 39in. mean absolute chord)
Weight: 125lbs. (AMA LMA2 legal)
Engine: Fuji 500cc 2-stroke inline twin, air-cooled, with turbocharger (200hp@7000rpm)
Prop: 26", carbon fiber, 6-blade, variable-pitch unducted fan (aka, propfan)
Fuselage and wing construction: aircraft-grade plywood, spruce stringers, and carbon fiber/zylon+carbon nanotube-reinforced epoxy skin.
The aircraft will have redundant systems, including:
Dual receivers (Futaba)
Dual GPS-compensating PowerBox iGyros (gyro gain automatically decreases with increase in velocity)
(4) Four LiPo Receiver batteries with no-fault switches (automatically switches to the good battery in the case of a failure)
High-spec items will be used for additional safety, Including:
Hybrid ceramic engine bearings rated to nearly twice the max engine RPM (continuous rating) and a load saftey factor of greater than 2.0
UAV grade (FAA approved) bladder fuel tank and pump
Genuine GE Lexan canopy
Tonegawa Seiko UAV-grade servos (directly driving the control surfaces--no linkage to fail)
Control surfaces will be mass-balanced (multiple points)
Aircraft-grade aluminum and rivets used on engine subframe assembly
The entire aircraft is currently undergoing FEA/CFD simulation/testing to determine weak points/ turbulence as the design approaches the transonic flight regime.
A link to my inaugural Youtube video will be coming soon. (whenever I can enlist the help of my stepson, he's much better at the video editing stuff). Picture to follow...
This.Is.Not.Vaporware.
Delta Aeropace
Change IN
Hello to all,
Length: 96in.
Delta Aeropace
Change IN
