The Props Aren't Always The Only Sharp Things That Spin
Snarls
Gravity Tester
Check out this video from Tested. Jamie Hyneman attaches a circular saw to his quadcopter to do some landscaping...or is he preparing for the zombie apocalypse?
It's one use for a multirotor that is unique because it does not involve a camera or cargo transport.
jipp
#2
i think, there are better ways to achieve this :D
but who knows as i think he is into robot wars, maybe quad wars will be the next big thing in robotics.
chris.
Cyberdactyl
Misfit Multirotor Monkey
#3
As much as I respect both Adam and Jamie from their extensive builds and experiments, they occasionally surprise me with obvious hair-brained contraptions.
As well as they both understand physics and engineering, Jamie still completely missed the fact a rotating cutting blade needs either plenty of inertial mass, or mounted resistance to cut pretty much anything beyond gel or light foam. I strongly suspect even mounting the blade rigid to the MR would only provide marginally better cutting, and that is IF he can maintain control.
Cyberdactyl
#5
Yes, now that hanging beast has some mass. I would be curious whether or not all the blades spin the same direction. Three choices. All rotating 'down. All rotating 'up'. Or every other rotating different. Each, I would assume, has its own issues and precautions.
jipp
#6
yeah that has a lot of mass ( 900lbs ) and 10 26" blades. impressive pilot.. hope they paid him a good bonus. so many things could go wrong in a flash with that setup.
some better footage.
chris.
Snarls
Gravity Tester
Haha good find Balu. I don't think Jamie's intentions are that devious. Also the rocket at the 4:10 mark is an Estes model rocket; I have the exact same one at home.
