Ok, so dragging this thread back on topic (hey, it's not like I've had my share of dragging threads off) . . .
We last left off with a tested power deck so . . .
. . . We all need a little more control in life
and I mean little:
This tiny guy has most of the features of it's bigger brother, minus a lot of weight
and minus attachment points too . . . tricky. we'll use this side, keeping everything flush with these connectors.
Now flip it over and test fit again:
Perfect. plenty of space in front of it for the RX.
Speaking of receiving . . .
Now one of the issues with this particular board is it's designed to work with ppm and PWM, but no accommodations for a Sat or S.Bus port. What's not stated is this is a native Naze32 clone, which means the RX inputs naturally remap to Sat and S.Bus inputs, the only thing missing is 3v power for the sat. Never fear, I have a trick up my sleeve . . .
. . . the bootloader pin doesn't short to ground. It shorts to 3v. find that pad, and I've got the power I need!
a bit of poking-and-prodding and there it is. this pad is shorted to the STM32F103 chip's power pins *and* the output pin on the voltage regulator over in the far corner. so I add on a milled socket for the sat's power connection . . .
And now for Spaghetti . . .
. . . and I'm set for the RX. Now to wire in the ESC cables before I mount the board . . . no snese in letting the wires I extracted form the ESCs go to waste, let's use those -- wire in #1:
through #4
now here is where I found 1-4 didn't lay out well for which direction the cables went. no worries. just lay them out around each other. best way I found for these was swapping the middle 2 first (2 & 3), then overlaying the swapped outer two over top of those (1 & 4).
Add on a lead for power (I used some more scrap of the ESC wires . . . I've got a lot left over
I can tell you where to stick it . . .
. . . and now it's time to consider mounting. I'm going to go with mounting tape, but I need to make sure the lights are unobstructed. there are 3 LEDs on this board, one in the bottom left corner, and two just forward of the white connectors.
so cut a piece of foam mounting tape too big, and make sure the LEDs aren't covered . . .
. . . then cut it away from the connector
. . . and repeat -- took 3 layers to get a full layer above the connector.
Then shave the foam down to a flat surface, level to thee connectors.
and that's a nice flat surface, ready to mount.
add on one more layer of extreme mounting tape (good stuff!), and . . .
Stick it on!
So now it looks more like Cthulhu than a control board . . . but we'll trim some tentacles before we're through.
Whew, whata ride!!!!
yeah, tonight's was a long one . . . split this in half, so it should be more readable . . .
next we'll install the RX, deal with repairing evil pads and make a first pass at setting up the board
