nevenelestate
No Agenda FPV
I "landed" in a tree in my yard, it was up there for about a week, and through a rain storm or two. The brown foam board is good, but not that good haha.
The F411-Wing fits perfectly into the slot that FT designed for the PDB, just make it a little longer front to back, I think back worked best. When you install it glue the blank PCD, bottom plate, to the foam WITH THE STANDOFFS INSTALLED TO IT and then you can just screw the FC board down to it. I think you might want to try a smaller VTX, this AKK X5 one would be good.
This was where I placed my VTX, although you will likely need to fit the SplitMini PCB up front, the tough thing with the SplitMini is you need to be able to access the SD card to get your files off it.
This is how i later got my GPS mounted in the back of the fuselage, I believe I had to cut a bit of the foam out of the top cover piece.
