*Unofficial* FT Simple Cub
Sadly the B power pack recommended has a bell type motor the CF2822. From my own experience I find that the motor mount is easily damaged, works itself loose and the motor shaft is very easily bent. I won't be ordering the B pack as I envisage handing mine off to a club newbie and I do not want to make a rod for my own back!
Just doing a quick search of HK I think I will be ordering and using the Turnigy D2822/14 1450 Kv and a suitable SF prop or perhaps a similar motor with a slightly lower Kv rating.
At least I will be able to source new motor shafts!
Have fun!
I'm in the UK so I tend to just order the most suitable motor I can or usually, use whatever I have.
In my usual fashion I'll use a motor I already have that isn't entirely suitable. I have a 1900kv 2826 that can take a 7x5 on 3s. Should do for now.
GKNIPP
Just wondering if the plans for the floats will be released with the Simple Cub as well. I can't wait for the plans to be released. Such an excellent design. GREAT JOB!!!!
uLightMe
Racerstar BR2830 1300KV
Hi, I know that the recommended power pack is B (EMax 2822) but I'd like to know if a 2830 1300KV would also work and perhaps, what (if any) issues can I expect by using this bigger motor?
I appreciate your help.
SP0NZ
FT CAD Gremlin
Admin
I have not seen the floats yet, but I would expect they will be released shortly after the Cub.
SP0NZ
FT CAD Gremlin
Admin
I plan on trying it with a bigger (C-pack size) motor myself.
French
Construire Voler S'écraser Répéter
Sponz, I asked the the Tubby thread, but I'd like your input too. Do you think this would fly well with a 2205 2300kv motor on a 6x4.5x2?
I realize I'll need to come up with a mounting solution.
SP0NZ
FT CAD Gremlin
Admin
That might be a bit of a challenge. I think this plane might be a little too big for a mini sized power setup.
rockyboy
Skill Collector
It will certainly swing the recommended 8x4.5 prop with ease - and going with a bigger prop will just get you closer to that 3D hovering and unlimited vertical performance.
I think the main thing to watch for with the bigger motor will be the weight different and moving the battery back a bit to compensate - I think the design will have plenty of lift to account for the weight though, it'll just increase the stall speed a bit.
rustygunns
Wooohooooo, got the notice yesterday. shipping says it'll be delivered on Friday. with any luck I'll be at the field with it saturday
As always thanks for the plans FT and Dan. Also just printed them in the new B Size. Thanks for that new time saver too Dan.
SP0NZ
FT CAD Gremlin
Admin
What is the difference between the "A" and " B" size drawings please?
A-size is the normal/standard tile size that all of the previous plans have used. It's setup to print on US letter (or A-Size) and ISO A4 (metric) paper sizes. That's your standard 8 1/2 x 11 paper that most home/office printers use.
B-Size is new and meant for US ledger (or B-Size) and ISO A3 (metric) paper sizes. If your in the US, that is 11 x 17 paper. I've had a lot of request for this size to be added.
