Description:
You can fit it all in the new FT SPEAR! This plane was designed to be able to carry all your gear when you fly! you can put your GoPro, board camera, 2 batteries, FPV gear, and even a vector system, if you have one. The Spear has a unique center console that is made larger and wider for the very purpose for storage. The larger wing allows for a larger payload compared to the FT Mini Arrow! This wing also allows for you to strap/tape bendable tripods with cameras for different ariel viewpoints if you are trying to get that epic shot! The Spear also is super stable and allows you to perform acrobatically challenging maneuvers with ease!
Release Date: 10/5/2016
Article: http://flitetest.com/articles/ft-spear
Release Video:
Build Video:
Plans: All-In-One | Full-Size | Tiled
Specs:
WEIGHT WITHOUT BATTERY: 1.45 lbs (658 g)
CENTER OF GRAVITY: 3 – 3.5” (76 – 89 mm) in front of firewall
CONTROL SURFACE THROWS: 16 ̊ deflection – Expo 30%
WINGSPAN: 41 inches (1041 mm)
RECOMMENDED MOTORS: 425 sized 1200 kv minimum
RECOMMENDED PROP: 9 x 4.5 CW (reverse) prop
RECOMMENDED ESC: 30 amp minimum
RECOMMENDED BATTERY: 2200 mAH 3s minimum
RECOMMENDED SERVOS: (2) 9 gram servos
Speed Build Kit: https://store.flitetest.com/ft-spear/
Power Pack C: https://store.flitetest.com/power-pack-c-fixed-wing-large/
Plywood Accessories: Coming soon
Super Spear: Check out mad scientist Chad Lewis' frankenspear (a.k.a. Super Spear) in the FT VLOG. Super Spear shows up a 6:12 in the video.
