You going to use the Java program for analysis?
Same problems everyone has, solve one issue raise a new issue. Full size CS props aren't the panacea either but like you said, pitch is changeable. It would be interesting to make a fixed one and compare to the CSThe twist isn't that good for static and low speed
PROPS are like haircuts: everybody thinks theirs is the best. Base test prop should be whatever you can easily find in 3 blade wooden since you won't find a planform like yours, similar base pitch is going to be hard enough. Bloody pricey, too.
choice is nylon but those do odd things loaded and I am not a fan of side viewing running props.
just interested, why do use cura and not prusaslicer if you have a prusa printer?View attachment 233707
OK... lessons learned or figured out after hitting the Print button.
The Good
- Running the filament in the X direction with the primary loads and being pretty much solid, these are WAY strong. I just did these in ABS and was really expecting this to just be a dry run for fit and verifying the mechanics. I'd expected to go to Nylon for bench and flite testing. If a single blade can take only 1 pound of load, the propeller would be twice as efficient as a store bought version. I doubt that would happen, but I'm sure 1 pound will be no issue for this blade in ABS. I'm pretty sure I could use a hammer on this and it still be usable. Since this set are sacrificial for other reasons, I'll do some destructive testing.
- ABS blades will be very easy to post process... fuse, fill, sand, balance will be far easier with ABS than Nylon, PC... etc.
- Top - coming off the printer.
- Middle - fused only
- Bottom - fused, sanded to take off the brim and nits and knock off the steps particularly on the leading edge. One coat of ABS/Acetone wash fill and sanded at 120 grit. I figure it might take one or two more coats and sanding to get down to 400 grit and then painting. Should look near as good as any injection molded prop.
- The shape is VERY nice. I think it came out better than even the Vase mode prints.
The Bad
Onward and upward!
- You'll note I added a sacrificial shaft at the base so I can put it in a drill and turn to polish the bearing surfaces. But I also stupidly added the control arm which defeats the turning ability. Dah!
- The control arms seems plenty strong enough, but I don't like relying on inter-layer strength. I'll be printing the arm separately and in the printer bed plane to get better strength for the push rods.
- I used simple bevels for the bearing surfaces which will make it harder to polish. I'll re-do the joint to us fillets that match my modeling files. Make it easier to post process.
- I've got my 3D printer well calibrated and it will do a near perfect circle in the bed plane. However, when the circle has one axis in the horizontal direction and one in the vertical, the different CTE values cause the circle to be ovoid. The horizontal is 96% the size of the vertical. I'll need to compensate for a second printing.
Sorry I interpreted this as a like for like comparison. Jury is out full scale as to whether a 2 blade is more efficient although theoretically it should be, and a 1 blade being the most efficient
I like APC props. They are affordable, tough, make good thrust, and best of all made in the U.S.A.!I was kind of thinking more about getting a top quality prop as the baseline. Can you recommend a prop?
My motor is a D3536, 1000KV. It's suppose to max out at 435 watts. The Amazon add says a 10" prop is recommended, but doesn't say anything about pitch. The 3DLabPrint plane this will go in is the TA 152H and they recommend a 10 x 5.5. What is a best brand of prop? Hopefully not one that will cost more than my motor and DIY propeller?
435 watts should be max constant.. start up and throttle changes will exceed that momentarily. IR optical heat sensor to check you're not exceeding say 150f assuming the varnish in the motor is rated for 180f.
https://www.amazon.com/dp/B000W0LBRO/?tag=lstir-20 I am not being paid for this endorsement. Lol
Also, for your cheap motor this 750kv says the recommended prop is 13x8.
https://www.amazon.com/dp/B084QCLTM1/?tag=lstir-20 Just be sure to sand the shaft with something course and crank down that collet or you will be landing dead stick.
This is another cool project. I like to see you guy's big brains working.
The blade's foils and twist have been aerodynamically optimized for 150 mph. As mentioned earlier, the variable pitch should take care of takeoff and low speed flying even though sections of the blades won't be pulling their weight. It will be interesting to see how all this theoretical plays out.
Printing... my first series of blades are really just proof of concept for the variable pitch mechanism. I've actually made them hollow with sparse 3D printing Infill. Just for grins, I continued the spreadsheet to analyze for strength. I've used the weakest material properties I can find and am only using yield strength. That way I can take advantage of ABS large difference between ultimate and yield as an indicator... to back off as they start plastically deforming forward.
Even though these are relatively weak, stress calculations say I can drive these up to 3600 rpm before reaching yield. I may have to run these to destruction for validation. Probably outside would be a good idea.
3600 RPM doesn't sound like very much for an electric powered model. A 23x12 prop turning 3600 rpm would have a pitch speed of about 40mph.
