Gee, that thing looks amazing! Nice work @bracesport!I am pretty impressed after doing the sausage wrap for the first time - canopy step is good - surface needs a little tickle up but it is not half bad - dry fitted the tail and it is starting to look like a glider!
View attachment 173246 View attachment 173247 View attachment 173248 View attachment 173249 View attachment 173250
Cool procedure]@Boberticus - this CF weave is not pre-preg so I either spray glue it to a surface on in this case I stuck tape to one side to hold it together while cutting the strips - epoxy went on the foam side - CF strips were pressed onto the epoxy and the tape ended up back to back in the middle - next I will separate the wing halves again, remove the tape (and trim the excess), then epoxy down the middle of the spar.
Very impressive work you doThe strips of CF adhered to the wing halves and with their backing tape removed I could easily epoxy the spar together - I will still need a little trimming on the top surface after glueing - I am also printing some end caps for the wings to help with aligning the wing tubes and rotor pins.
View attachment 173374 View attachment 173375 View attachment 173376 View attachment 173377
