Hi guys, I wanted to hear from YOU what plane I should get. If you watched the "Flying through glass" episode, you'll know what I'm talking about.
I would buy parts and build your own plane!!
2) Start with small steps.
3D may look cool, but don't leap into advanced planes until you're ready. Frustrating is the word for that.
+1 if these are your only two choices- go with the BixI think that you will need almost the same space to fly a wing as you need for the bixler (when you get used to them).In small areas you will probably need to circle them down instead of the normal “square landing procedure”.
I would say a bixler or similar for the first plane. 3d sounds great but its a bit harder than most
think and if your
flying indoors then hovering would be about it then you just as well get a heli.
I am fliying a nine eagles sky surfer at the moment and it is a perfect beginners plane.
On a final note, a scratchbuild is a big undertaking for a first time flyer maybe better to feel
how things move through the air and how you respond to them will give you a better feel on what to build at a later date whatever you decide just enjoy the beauty of flight...i do every time
A guy once told me "get a plane based on where you can fly and is close". Actually quite true. I wouldn't even half as much as I do if I would have got something that needs me to hop in a car and take a longer journey. I have a lot to do after work when I get home, so the ability to step out and walk to a suitable field is bliss. I have a Kyosho minium edge, just because it's super small and fun. Then I have a bunch of others, amongst them a Bixler. I love the Bix as to me it's the most relaxing plane to cruise with and can carry fpv-stuff. Then I have a heli and edge 540 for more challenging flying.
So it's really not listing what you would like but what you don't want or isn't convenient. After that you have a basic idea of what it could be, then just pick a suitable one. Elimination is the way to go as you cannot have all of them... Or atleast my wife told me I cannot buy them all...
As an experimented RC nitro car pilot ( and after very much money spent! ) I bought an EDF jet! ( I know...bad choice for a start)...well, so far it was a not a waste of money...My jet survived 14 crashs..yes fourteen! and all it took was some 5 minute epoxy and I was flying again....so in MY opinion EPO, EPP planes are the way to go if you are starting, jets would not be best buy for a noobie but I got away with it thanks to a week of practice on a simulator....fiber glass?...crap!....balsa...crap!...EPO=survivor plane!!:applause:
If your just using to blow through glass go as cheap as you can....But If it were me and and I was to use a Bixler, I would Cover the nose with cut Sheet (aluminum) or simple glue a ball bearing to nose tip and mold a clear canopy for the fpv cam in cockpit... This plane is a very controllable platform so you should be able to hit it first try... and still could be used later for what ever...good plane ---great with large brushless motor.:black_eyed:
