No pictures today. I took time last night to make progress in a couple of minor places. I have a few e-tract units in my stash and started rummaging through them to find something that would work for the tail gear. I found a suitable one but the endpoints were funny and not consistent per my servo tester. So I swapped out the motor and control board form a good unit of the same size to the case and setup that I knew would work.
I also looked through my stash of offset hinges to figure out how the landing light would work. I think I have an easy solution for that so I drew up the reflector in Fusion to print later. I also dug around and found a micro switch that will cut off the light when retracted.
Need to finish up the OCWG situation. The other one needs to be assembled, the can paint needs removed, and the prints themselves need to be smoothed out before I can install them into the airplane. Once that is done, I'll move onto the intercooler doors on the sides of the fuselage.
