Theoretically yes but I don't think the difference would be that great. Mine didn't even have enough thrust to scoot along the floor. It's basically like trying to run a power pack C plane on a power pack A. Give it a go though, maybe I'm wrong.
In my own experience with a Viggen on a 3d printed EDF, it was pretty relevant to trying to fly a C pack plane with a F pack motor (because that's basically what you're doing) It flew, but it really felt under powered and could not climb quick at all without stalling out. The Viggen however is good low speed charactaristics to help it fly at all however!
It is approx the same size as "70mm EDF." I took the plans and used the 73mm hole in the motor bulkheads and used that as the outside diameter, I believe it's 69mm ID. If it doesn't make enough thrust then I guess I'll have to buy an EDF
Side note, shouldn't a 18xx motor size, vs 22xx motor housing, allow more air to flow through?
I recently made a 3d printed 70mm EDF motor, 12 blade, powered by a 2207 2500kv motor. running it in my Viggen on 4s.
I do not know how much better or worse a lower blade count would be for the thrust, but I can say with absolute confidence that it produces WAY less power than a proper 70mm EDF would. The Viggen is a great lower speed jet, and it flies, but only just, It's massively under powered.
My father built a 90% scaled down Viggen, same 3d printed EDF but with a 2700kv motor. It's 20% lighter and flies a little better, but even on 4s, it still isn't anywhere near what the 70mm EDF I just purchased can do on 3s. (Which I purchased specifically so I can build this jet starting this weekend!)
I only caution you because a ~70mm BDF will still produce way less power than a 70mm EDF would, they need to be larger to compensate for smaller motor size/power, and the plane needs to be real light for it to work.
Now I do not have any measurements or data to back up what I'm saying currently, Just wanted to throw out my own experience with using a smaller motor to try to be a cheap alternative to the real thing.
based on my experience I wouldn't attempt this plane on a 2207 motor setup. But it will be interesting to see how yours performs.
