OUch. Sorry to hear about the ESC's burning up. I'm not clear. Did they burn while just connected to the receiver directly or connected to the MultiWii flight board? When you were doing the calibration, using the receiver direct connect method, did the motors run up ok?
Were the motors directly soldered to the ESC's or connected via bullet connectors? I have what I thought was a longish run of about 12cm to the ESC's, but 35-45cm does seem like quite a bit more. Still, I wouldn't think it would be a problem.
I also wouldn't think the tail servo refresh rate should affect the motors/esc's. I know it may sound silly, but with disconnecting, reconnecting leads/plugs, especially if tired or not paying attention, one might plug the wrong ESC or servo leads into the flight controller. I wouldn't think a servo refresh rate would be incompatible with the ESC's but I do think that a motor plugged into the tail servo pins might be bad because it would be sending a PWM rate of around 1500 to the ESC, which might put it in programming mode, or it might run the motor up once it's booted.
Sorry, but I'm sort of just making guesses at this point.
