Yak-55 3D Dollar Tree foam board build
cjhagemeyer
so the first one i built had a 48.5in wingspan, and weighed 760g. But for that i only took the paper off of one side of the foam and used hot glue to glue it together and on top of that used an arrow shaft as a spar which is about 30g, and then all of my electronics. for the new one im building im using a balsa spar which is about 6g and taking ALL the paper off, and not using hot glue to glue the pieces together. my goal is to get it around 600g auw. which is lighter than this one which is a comparable size
Goose 51
If I'm using 1 layer of paperless dtfb instead of two, can I still use an FT f pack? Is it under 200 grams?
Tench745
Can't speak to the plane specifically, but if I remember correctly, the paper is about half the weight of DTFB. If you remove the paper and double the foam it will weigh the same. (Plus the weight of the extra glue.)
Goose 51
Sweet, I didn't know that, thanks for the tip
Zokyy
First a little back story. I thought flying a 3D airplane was way beyond my abilities. I'm a slow-fly and glider type of pilot. A couple of weeks ago one of the guys at the RC field has a EPP foamy profile 3D Extra. He's no 3D pilot either. He tells me I have to fly his new airplane. I think he's out of his mind. I'll destroy it. So I fly it anyway. :) I was amazed at how easy it was to fly. So slow and floaty. It wasn't twitchy at all. It felt slow and smooth. I was doing my short repertoire of stunts with ease. A tight loop looks like a backflip. It rolls like a drill. Flying two mistakes high is only 30 feet up. I gotta have one! :D
I searched for plans and find one of the most popular and most copied 3D out there is Leadfeather's Yak-55. Plans galore. 32" wingspan; downloaded it. For the first time ever I make templates from the plans. I know for sure I will be making more than one. The retail foamy I flew was made from 9mm EPP foam. I don't have any EPP but I have lots of Adams foam board from Dollar Tree. When you peel off the paper and glue two sheets together you have 10mm sheet foam. Close enough.
Here's the first shot at making a 3D airplane.
Two sheets of DTFB, no paper, glued together with spray adhesive.
Templates arranged on one sheet of foam. The other half of the wing goes on a second sheet.
These are all the parts cut out. I don't think I've made an airplane with this few number of pieces. If you had a big enough sheet of foam it could be even less parts by combining the horizontal parts before cutting it out.
It's late so I'll continue the build thread later. Stay tuned...
<edit> Plans and build instructions attached.
Jon
Guys tell me that which paper format should i need to print in the shop A0 or A1 sheets ??
heckerp1
Hey guys,
I was thinking of building this with XPS insufoam. What thickness should I go for?
As for the electronics, I have a 1800kv 2204 24g motor, 12A esc, 8040 propeller(CCW), fs2A receiver, one 3.7g servo and one 1.8g servo with 2S 650mah 45C lipo. Will this be alright to fly?
Also if someone could please answer @Zokyy 's question (I was wondering the same 🥲)
Proptastic
Hey guys,
The thinnest stuff you can get is fanfold. It's about 1/4" thick. It's a lot lighter, softer and more brittle than DTFB, so will most definitely need reinforcement bedded into it. Your airframe will be extremely lightweight and 2S power should be just fine.
heckerp1
fanfold? I had thought of using some xps insulation foam (blue) which are sold in blocks of 25mm or 30mm, by cutting them into 6mm sheets.
Also I am thinking of building the 22'' version, will this be alright?
Proptastic
Fanfold is xps. Around here it comes in 4' x 8' sheets of different thicknesses, and fanfold. But yes you can cut thick ones into thinner ones. The stuff I used is also blue. I never did use it much. I had a mini F22 that disintegrated when crashed on a vineyard wire. I still have a mini Mustang and a Viggen that's built from it.
heckerp1
Oh really? I havent worked with DTFB before (not available in my region at all) so I didn't know. But I was planning on adding Carbon spar reinforcements. It should work with that, right?
Also I am confused on what thickness I should keep. 3mm? 5mm? 6mm? or go all out with 9mm (expecting about 250g max thrust with motor on conservative side)?
Also should I tape all surfaces to prevent it breaking during crash?
Proptastic
I like carbon the most.
6mm, or 1/4" thickness is usually the standard. You could go as thin as 3mm on something like a micro build. You would use thicker than 6mm for something like a monster scale build.
I have an incomplete 200% Bushwacker made of 1/2" and 3/4" xps, with aluminum reinforcement.
For a 22" Yak, stay around 6mm or your wing will be thick and chunky.
heckerp1
Alright, so 6mm is the go to size. Also should I consider taping the surface?
The Hangar
Fly harder!
Is your Viggen the hotwire version ft made?
