Again - congrats on a great looking plane and some lovely scale flying.
Quick question - you mention in the video that you have a separate battery for each motor. Do you have them paralleled? That is, do you have a loom running between them to wire them in parallel. The only reason I ask is that when I built an 80 inch twin plane (two independent 40 inch planes joined at the tips), I installed a wiring loom so that I could connect the batteries together in parallel with the goal of keeping the two balanced with each other. I did not have differential thrust built in and I did not want to have to deal with one battery discharging faster than the other leading to yaw. It worked great, every time I came down, both batteries were always at the same voltage. I plane to do the same for the 160 inch (4 x 40 inch) monster. Thoughts?
DamoRC
DamoRC
