orange_rc_pilot
If he can, then so can I!
I'm thinking of building a 180% FT Racer over Christmas, and I am not quite sure that I'm using the best power setup. My aim is to fly at 70mph (112kph) for fast low passes, but also to be able to fly a gentle 35mph (56kph) for smooth scale flight. I will be using a 50-sized motor, with 2000w and 580kv, running 4400mAh 6s and a 15x8 prop. Having used both Webocalc and HobbyKing's prop test data, I have established that I will have 6kg (13lbs) of thrust (give or take a few hundred grams). I am estimating an A.U.W. of 3.5-4.0kg (7.7-8.8lbs), and I was wondering whether my system is about right, under-powered or over-powered.
All comments are appreciated.
