SnowRocker88
Amateur pilot and builder
Min command is the lowest command the FC will give, Min throttle is the lowest it will allow the motors to spin (min command must always be lower than min throttle) . If you ever adjust min command or max throttle you need to recalibrate the esc's s that is the values they work off. Go into the motor tab and check what level the motors start turning (it should be around 1050) then set min throttle just above that point and see if things improve.
So, what should Min Command be set to? I don't really get that. Just something below Min Throttle or is there an actual correlation with something that I should look into?
I will check again but I did check what command made the motors spin and it was like 1150, thus I set Min Throttle to 1160.
