MojoFlyer
Parked/Landed my FT Tiny Trainer high up in a pine tree this evening after work. Tromped around in the thicket of vines and smaller trees below breaking rotting limbs off to try and throw at my plane. I hit the plane a few times, but it didn't budge. Got all scraped up in the process. Then I remembered one of my other hobbies/interests.... Tree Climbing. I went home and got my throw line and throw weight. This is the tool that tree climbers fling high up in the tree to then pull their climbing rope up and over a solid limb. After a few tries, I was able to throw the line over the limb my plane was stuck on and then let the weight down and grab both ends of the line. Using both ends I was able to yank on the limb until it turned loose of my plane. Then the plane got stuck in the next limb down and I had to repeat the process. I finally got my plane back in one piece and the only damage was to the prop. Here is a picture of my throw line kit:
WEAVER D SERIES THROW WEIGHT 12 oz. ($11.95 www.treestuff.com)
New England Dynaglide Throw Line 150 ft x 2mm 1000 lb test ($24.95 www.treestuff.com)
WEAVER THROW LINE STORAGE BAG Small ($9.95 www.treestuff.com)
Using a throwball / throwline: https://youtu.be/jFyu8rgRHAQ
Hope this helps somebody.
