No I didn´t use the Turnigy straps but they seem to be the same. At least I think they are same sold by another shop in Germany.
They have a very good adhesive on theyir back, so yo don´t need to mess with glue and stuff.
I have a Turnigy switch lying around but I thought of using it in my Event 3D because I wanna be able to switch with that one. not sure though because I don´t want the plane to be too heavy.
However, I have a liitle problem with my Tricopter.
I soldered my connections from the receiver to the board and with my last flight in the living room, sometimes I had glitches in my control.
The Tricopter mostly just suddenly fell to the left for a fraction of a second.
Then when I crash a little harder, my receiver fails to respond AT ALL ! No arming, no disarming or anything like that.
I have to rebind the receiver most of the times. Only when I really play around with the wires etc. it might respond.
I know this usually shouldn´t happen. The first flight didn´t have that issue, so I think the first thing to do is try and look at the solderjoints and the connections, but when I did last time, they all seemed good.
Btw. the connectors do seem to be kinda loose on the KK board. Does anyone have an idea of how to get that away? They are not too loose to come off themselfes but I still think it might something to look at with this.
Btw. I am on holidays with my family (snowboarding
) so I don´t have access to my Tricopter, but I wanna know what to do, as soon as I get home. Also I ordered some Propsavers. I look what I can do with them, because my 3,17mm don´t work properly and keep coming off after a while. Okay that should be it for today. I can only check on the forum on the evenings, but I hope to get some suggestions about what to do.
Also further question: Which Tricopter firmware are you using? I just flashed it with the newest one. I think it is 2,6. Which one do you recommend?
