Is there by chance going to be a build video or a build article or anything with this? …
This is version 0.1 of the build plan and the plane is still in the BETA stage. I don't plan to make a video about the assembly, but I could make a photo series for version 1.0. After all, it's an entry-level model and should get a guidance.
… I can build a FT plane usually with minimal video help but after reviewing your plans it looks a tad difficult. Those inner spars look super tiny. Are they just thin strips of foam? …
I have labeled the areas in the build plan and marked them with green dash dot lines where the spars are to be glued. Yes, the inner spars are only the four thin foam strips. Between the front and the rear inner spar, the servo cables should still be pushed through.
With the next version (0.2 or 1.0) there will be only one inner (center) spar, which corresponds to the outer spars except for its length. This strengthens the wing. The servo cables can also be pushed through the wing behind this spar. However, the opening for the servo cables contained in the wing must be slightly further back.
… The 2 pages in the plans titled AP_Eazy_Full.pdf, are they each the size of one sheet of foam?
The page itself has not the size of one sheet of foamboard, but the area in the page with the parts has the size of one sheet of foamboard. I always print the parts from the file titled AP_Eazy_Full.pdf. I use the snapshot and poster print function of Adobe Reader to print the part templates.
Have fun and if you have another question, don't hesitate to ask it.
