Hi Guys,
I have spent a lot of time trying to get the gimbal control to work via the APM2.6 and would like to share how I eventually got it working.
I was using the RC channel directly from the reciever to the gimbal but the APM should support the gimbal pitch/roll natively but in the documentation they always mention the Aux 9-12 channels however this is INCORRECT.
You have to attach your pitch or roll to the motor outputs!
So in the APM config screen for gimbal you select your input (aux 6 for example) and then your output is AUX7 or AUX8, these correspond to Motor out 7 or 8 on your APM. Obviously if you're running an octacopter then bad luck.
I hope this will help someone out there who is facing similar issues, I know a google search will allude that it is.
Cheers
Cheers
