To get the lightening stripes and windows should I also pick up a black cover pack? And how will I apply this all?Yes on the extra covering pack. That gives you some to experiment with!
To add to @The Hangar questions........is there a"Best Practice" sequence of covering that gives good results in terms of overlaps and hiding seams.To get the lightening stripes and windows should I also pick up a black cover pack? And how will I apply this all?
Hi There!@Willy Nillies I'm thinking about getting your J3 cub Beta kit for the balsa build-along and saw that you recommended a 1306 3000 kv motor for this. However, I have hardly any money at all to spend on this and was hoping I could use my 1808 2400 kv motor on a 6x4 prop? Thanks for putting up with my noobish questions. I know foam board but not balsa. If it's foamboard just chuck it in the air and see what happens. You might lose a couple bucks and a few minutes of repair. It's not that way with balsa
Edit: my setup allows me to bump the power up to 4s if need be but I suspect the 1808 on a 5 or 6 inch prop will be adequate running on 2s.
Thank you for your reply! I went ahead and ordered some 4.3 gram servos for this build, and I think I’ll go the safe route and buy the gear you recommend. I emailed you about the $5 off coupon, also thanks again for your generous offer - I can’t wait to get started on this build!Hi There!
The 1808 would probably work on 2 cell 500 mah, but way more power than needed. You will probably have to add a little tail weight to balance. Max 5 gram servos recommended. 9 gram servos will not fit in the wing or servo tray without extensive modification and adding unnecessary weight. All those 2 or 3 grams here and there REALLY add up on small airplanes like the Cub and will effect flight performance significantly.
With that said, we do encourage modifications and experimentation with our kits! If you decide to go ahead with what you have on hand, we will do our best to assist you to help make it work the best it can for what you have.
The Cub was specifically designed to be lighter than like the Barnstormer and modifications were made in arms/moments of motor placement, tail moment etc to get it to balance very easy with the the recommended equipment at the lightest weight possible.
Sincerely,
Doug and Becky
WillyNillies.com
I don’t have Facebook but otherwise I would. Will the black covering pack work for the stripes and all? Does that have to he heated up, or does it just stick on?If you join our facebook group, we will include enough material to do the black lightening bolts and windows. But you MUST request the material in the notes section at checkout.
SIncerely,
Doug and Becky
WillyNillies.com
@rockyboy , Add me to the list. I ordered a Hummer 250 with the aluminum landing gear last night and I already have a shipping confirmation.
Wow, that is great service.
What can I use to heat the yellow covering with? Will I have to buy something special or is there a household tool that will do the job? You can tell I'm an absolute noob to balsa!You will still need to heat up the black covering to get it to stick - or use a chemical activator like Monocote Trim Solvent (I don't know what the magic ingredient is in there, but there is probably a cheap / household option if we can find a chemist to help out).
I used a regular clothes iron and that worked well for me.What can I use to heat the yellow covering with? Will I have to buy something special or is there a household tool that will do the job? You can tell I'm an absolute noob to balsa!
Ok, good to know.I used a regular clothes iron and that worked well for me.
Simply put in the notes section that you would like enough material for the lightening bolts and windows and we will send it.I don’t have Facebook but otherwise I would. Will the black covering pack work for the stripes and all? Does that have to he heated up, or does it just stick on?
Sincerely,
Doug and Becky
WillyNillies.com
Thanks so much! I will do that!Simply put in the notes section that you would like enough material for the lightening bolts and windows and we will send it.
Sincerely,
Doug and Becky
WillyNillies.com
Ok - thanks! I will read it!I highly recommend reading through this thread that @Joker 53150 put together on starting your first Balsa build.
https://forum.flitetest.com/index.p...uild-your-first-balsa-plane-start-here.32389/
We will always be happy to keep answering questions here - please don't think I'm trying to shut you down - but there are probably questions you don't even know you want to ask yet, and that thread will help you figure those out too!
